1 - 11 of 11 Posts
I just change my rotors pads & lines. now my brake pedal hits the floor. There's no air in my lines. Is it the ams lines are bigger or something.
No, the ams line shouldn't be the problem. You need.to properly bleed the system. Cmc to slave cylinder and brake lines that go to the calipers.
Sent from my SAMSUNG-SGH-I727 using AutoGuide.com App
O damn thanks I didn't know that
Yeah I pumped the brakes but I only bleed the calipers
I found the correct way to bleed lines so ima give an update tomorrow when I do it
Discussion Starter · #8 ·
My car parked all I gotta do is drive 2 blocks
I'm going to be the smartass here and recommend that you learn the CORRECT way to do things before you actually DO it. :)
Yeah I know anything else I wouldn't even tried but for now on I'm reading up on things before I do it
Discussion Starter · #11 ·
Everything good now I had some air in my lines
1 - 11 of 11 Posts
