1 - 20 of 27 Posts
Anyone have any thoughts on why the pins on the rear brakes won't move? I did the fronts a while back and they moved easily when tapped with center punch...I'm stumped!
It's a spray, similar to liquid wrench. It's designed to free stuck bolts, pins, etc... It just removes corrosion to help free it up because that's most likely why they are stuck. Any hardware store or auto parts store should carry it. Just spray some on and around the pins, let it soak for a little, then spray some more and try tapping them out again.
PB blaster should do it and dont use a screw driver. I dont know what the tool is called but it is a long screw driver thing without the tip. It is just round and cut off, like without a flathead or phillips as the head.
I had a similar problem when I first tried this. And even PB did not help. Turned outI just needed to stop being a pussy and find the right tool and hit it harder.
[Team IEG VP]
The tool is called a punch. :)
put a rag on it and smack it with a hammer.
Discussion Starter · #19 ·
I went with PB Blaster, let it soak a while then hit it again with it then used the center punch to get them out...once that happened, took like 5 minutes per wheel.
Thanks to whomever recco'd PB???
The fail part was shooting brake cleaner in my eye!
1 - 20 of 27 Posts
