The other day I was flashing a map and it failed, I tried again and it failed, like a big dummy I took the key out of the ignition. Now when I turn on the Ignition on all it does is the fans spin, will not connect to ECUFLASH, and the car wont start.
So I researched and tried to upbrick it. I have been able to Alt flash followed up by a normal flash and they were both successful, but after I install the ECU the fans still spin, I can't connect to ECUFLASH, and the car will still not stop.
So I was hoping someone could help me fix this issue. I don't know if there is a way to fix it, should I buy a new ECU from the dealership, should send it in to tactrix for repair? (What if that doen't fix the issue?)
Here is how I was able to flash to the ECU directly.
