Hello recently I've installed an MAP Recirculating DP and replaced the factory manifold due to cracks w another oem manifold. After that I experienced some smoke on first drive and that stopped but I noticed when under heavy acceleration the car squeels. I've checked for a boost leak and there is none as far as I can see. Below are the things I've noticed so far. I've replaced the turbo,tensioner and serpentine belt. I'm at a loss on what it could be.
Symptoms
-low boost 3-5 pounds
-Loud squeeling noise when going into boost
Noise
Thank you for your help in advance
Edited 4/7
Symptoms
Noise
Edited 4/7
