The time has come to list the Evo for sale. The reason for selling it is due to me getting out of the military and not needing the car payment until I have a steady job. The car is in great working order, and everything is sound with it. It is unfortunate that it has to go because Dsport wanted to do a feature on it, but financial security is more important at the present time..
Flaws:
two small rock chips on the left side
a small scratch on the driver's side skirt
small rock chips on the front from highway driving
a chip in the paint on the front lip (pictured below)
Price: $31,000
Year: 2008
Model: GSR SSS
Mileage: 28,700
VIN: JA3AW86V18U050364
Modifications
Engine:
Buschur head
Supertech +1MM valves
Supertech dual valve springs
Kelford 214-B cams
Darton MID Sleeves
Buschur Spec JE Pistons with coated skirts
Manley turbo tuff I beam rods
APR head studs
ETS intake
ETS 3.5" MAF housing
ETS recirculatin DP
FP Red JB turbo
FP 18psi Wastegate
FP Oil feed line
Full Race Pro-stock tubular manifold (ceramic coated)
AGP front mount intercooler
ETS upper intercooler pipe
ETS lower intercooler pipe
Tial Q blow off valve
Fuel injector clinic 1100cc injectors
Boomba fuel rail
Buschur doublepumper (twin 255 fuel pumps)
Sheperd Racing Transmission with REM ISF on the gears
AWD motorsports aluminum driveshaft
torque solutions front motor mount
MAP clutch fork stop
Carbonetic single disc clutch
cp-e test pipe
litespec titanium exhaust
AMS under hood and shifter base bushings
Vented catch can setup
Perrin MBC
Omni 4 bar MAP sensor
Ported intake manifold
Boomba ported 64mm throttle body
Suspension/brakes/Wheels:
BC coilovers
Whiteline rear sway bar
Whiteline roll center adjustment
Ferrodo DS2500 brake pads
Enkei RPF-1 18x9.5 +15 wheels
Dunlop Direzza Z1 star spec tires- 245/40/18
password JDM red lugs
Interior/Exterior:
cp-e gauge pod
AEM oil pressure/boost/ wideband gauges
works short shifter
works shift knob
rexpeed VR style lip
rexpeed do luck style trunk spoiler
perrin shorty antenna
2010 gauge cluster
2010 tail lights
Flaws:
Price: $31,000
Year: 2008
Model: GSR SSS
Mileage: 28,700
Modifications
Engine:
Buschur head
Kelford 214-B cams
Darton MID Sleeves
APR head studs
ETS intake
ETS recirculatin DP
FP Red JB turbo
FP 18psi Wastegate
FP Oil feed line
Boomba fuel rail
cp-e test pipe
Perrin MBC
BC coilovers
Interior/Exterior:
cp-e gauge pod
works short shifter
works shift knob
2010 gauge cluster
2010 tail lights
