Hi, Im always trying to learn and was unable to find my the most pleasing answers that made sense to me so can some one break it down for me.
1. What is the purpose of upgrading cams?
2. Is the installation of cams, something you can add with out any support to that mod?
3. A tune is required from what I understand. But what specifically is changing about your tune? Is this where MIVEC comes into play mostly?
4. What do the different numbers mean to regular joe i.e. for the Tomei cams.
Poncam 260IN/250EX - 10.10mm(IN) / 9.50mm(EX)
Procam 270IN/270EX - 11.30MM(IN) / 10.70mm(EX)
Procam 280IN/280EX - 11.30MM(IN) / 10.70mm(EX)
Above lift measurements are valve lift, max cam lift below;
5. Why do you get the cool sound the chug chug chug sound? Does that have to do with the way the change of the lift effects the pistons or something?
6. Are cams considered part of building bottom or top half?
Thank you for your time evoxforums
warm regards
Navy:dancebanana:
warm regards
Navy:dancebanana:
