1 - 3 of 3 Posts
A 114.8-inch (2915 mm) wheelbase, wide front ( 62.7 inches / 1592 mm) and rear ( 63.3 inches / 1608 mm) tracks, and a fully adjustable, four-wheel independent suspension system combine to give the G8 a confident, sharp driving experience.
The front suspension features fully adjustable caster, camber and toe; the rear suspension has fully adjustable camber and toe, which enables more precise, tailored suspension tuning.
what do you mean by fully adjustable, is it manually by the owner or it adjust by itself depends on speed, road surface etc...
http://images.google.com/imgres?img...ges?q=g8+gxp&start=96&ndsp=18&um=1&hl=en&sa=N
User adjustable. They use a live rear instead of solid rear.
IE: You pay more for alignments cause you have to get the rear aligned aswell. If you own this car, make sure that wherever you take it, make sure they're aligning the back or you'll go through tires. Even some dealerships don't know they have to align the rear.
1 - 3 of 3 Posts
