1 - 12 of 12 Posts
Hello everyone, i recently started having an issue where my car doesn’t start on hot starts.
It starts up perfectly fine on cold starts. As soon as it is up to operating temps I can drive it fine and do pulls fine. Up until the second I turn it off, it won’t turn back on. It will keep cranking.
I can let it cool off for an hour or so where the coolant temps dropped some and it turn over a few till it stutters a little and give it gas till it starts up.
I was doing some research many are saying it can be the Cam position sensor, coolant temp sensor.
I am going to order a cam position sensor, and hope it fixes the issue. In the mean time I don’t want to keep my hopes high.
Spark plug are new.
Discussion Starter #8
Lmao, not yet.
I will try that when I get home, unplugging them and turning it over and reconnecting them.
After that I am sending the injectors out to get serviced and tested.
So did she start up and burn it off? Reconnect and start right up? This has always worked for me in the past.
Discussion Starter #10
Sorry guys for the delay still the same issue.
I am going to take the car to my shop as soon as I got the time to take it down.
I will let you know what they say and update you guys from them!
How is your MAF housed? Where is the filter? That's a common issue for cars with heat soaked MAF.
Discussion Starter #12
MAF Is up past the positive jumper terminal.
Filter is in the wheel well.
1 - 12 of 12 Posts
