41 - 46 of 46 Posts
Well at least I manage to flash....but still only a NA rom (2009 audm) I need a compatible evo x rom for it to run properly...weird...
Yes there are restrictions. If you are changing model years, you need to bench flash.
It may also be necessary to bench flash if changing car types.
Have you successfully performed a bench flash?
No... Still getting no known code reply
As long as it works, removing the turbo and back to NA anyway...
Nope, mileage can be changed with replacing the entire cluster. Seen a few Evo X's with the earlier central red display, change to the later colour display, it means changing entire cluster, and it's zero's the odometer.
41 - 46 of 46 Posts
