Did you end up finding out what it was?When i'm in gear, slowing down at about 20mph and below, a sorta of ticking/ clicking sound is heard, its a pretty constant sound as well, it does't skip. My assumption would be something from the rear diff. Any input? Thanks
I have that same problem currentlyWhen i'm in gear, slowing down at about 20mph and below, a sorta of ticking/ clicking sound is heard, its a pretty constant sound as well, it does't skip. My assumption would be something from the rear diff. Any input? Thanks
Mine is when I’m slowing down or when I let off the gas I hear repetitive clicking noisesI noticed it mostly happens when I’m turning but it would sometimes happen when going straight
I hear it was well but only when I’m almost to a stopMine is when I’m slowing down or when I let off the gas I hear repetitive clicking noises
What year and model is yoursI hear it was well but only when I’m almost to a stop
2013 GSR 58k milesWhat year and model is yours
Mines a lancer with the same noise2013 GSR 58k miles
I started a discussion and got this responseMines a lancer with the same noise
I noticed I could locate the sound coming from the transmissionI started a discussion and got this response
Check for any suspension components being loose ,
check your bushings on your control arms
If all is okay then it’s possible that your wheel bearing would need replacement
Check axles to see if you have leaky boots .
ive heard if you touched your clutch / awd system recently you might have to bleed the ayc in the front and rear .
