1 - 1 of 1 Posts
So I decided to do the clutch pill removal. But it turns out the last owner removed it already. I have a braided steel clutch line. I don’t think that matters. So I take off the clutch line off to find out the clutch pill is already gone. So I reattach the clutch line and I have my wife pump the clutch 5 times and hold it. I crack the bleed screw and the clutch pedal goes to floor and stays there. So I pull up the clutch pedal and we do the same thing again and it gets stuck again at the floor. There’s no air in the line. brake fluid is coming out. The reservoir is full. So I took the slave cylinder off and everything looks normal. So reinstalled it and it’s still doing it. I started the car up and it won’t go in any gear. The clutch pedal does not feel normal. I’m not sure what i did wrong.
1 - 1 of 1 Posts
