Back by popular demand are the Evo X 3" Turbo Inlet and Evo X Fuel Pump Holder!
EVO X 3" Turbo Inlet
The COBB 3" Turbo Inlet Hose is constructed using four ply steel-reinforced silicone, eliminating the issue of hose collapse that other inlet pipes suffer while under suction at peak demand.
While the steel reinforcement provides excellent stability, the silicone allows adequate torsional flex, allowing engine movement on the OEM engine mounts under hard acceleration without risk of separation.
This system uses all factory fittings and clamps.
Features
- 4-Ply Steel Reinforced Silicone
- Designed to be used with Stock Intake or Stock-Sized Intakes
- Smooth Inner Walls for Quicker Airflow to the Turbo
- Bulges to 3.5" to Increase Potential Air Flow Delivery
More info here: http://www.cobbtuning.com/Mitsubishi-Evo-X-3-Inch-Turbo-Inlet-p/752002-bk.htm
EVO X Fuel Pump Holder
Wanting to push your Evo X to the limit? An upgraded fuel pump is essential to feeding aftermarket fuel injectors once the factory fuel system has reached it's limits.
The COBB Evo X Fuel Pump Holder allows you to use a Walbro sized in-tank fuel pump without having to modify the factory fuel hanger.
It's durable delrin construction makes the COBB Fuel Pump Holder ideal for vehicles running high ethanol content fuels and race gas.
Features
- Delrin Construction
- E85 Compatible
- Works with Intank Walbro Sized Fuel Pumps
- Allows for a Plug and Play Fuel Pump Upgrade
- No Modification of Factory Fuel Pump Assembly
