Status
Not open for further replies.
1 - 20 of 82 Posts
Tons of good coilover options available for the Evo X. Give us a PM and we can help pick out the right coilover for you, along with offering very competitive pricing. Check our website out for all options, and PM us for the special EvoX Forums price.
AUTHORIZED DEALER FOR OVER 300 PRODUCT LINES
Like us on Facebook for Facebook only specials!
KW Coilovers - We have AMAZING PRICING on these!
KW Variant 3 Coilover System is state-of-the-art technology for the skilled and experienced driver. The separate and independent compression and rebound damping options allow a truly individual driving set-up. These unique systems with the 3 individually adjustable components, allows for adjustment of the compression of the damper in the low-speed range, while the highspeed set-up, so decisive for driving comfort, has been preset by our engineers
KW Variant 3 Coilovers
Fortune Auto Version 3
These are a great option for the budget minded racer. They are rebuild-able right here in the USA and all options offer custom spring rates and valving. Track Tested!
Click the images to learn more:
500 Series
510 Series
DREADNOUGHT© Inverted Coilovers
Eibach Coilovers
These state-of-the-art, race-ready, damping-adjustable coil-overs use a monotube damper design for maximum track performance. Ride height is infinitely adjustable between 0.80” – 2.5” lower than stock, and the dual-spring setup is dialed for maximum cornering performance. Rebound and compression damping are both adjusted-ensuring proper damping balance at any setting.
Multi Pro R1
Multi Pro R2
HKS Coilovers
With the Hipermax III suspension series, the driver gains increased wheel control with improved performance of all vehicle dynamics and increased driver command in all conditions. Hipermax III combines track-quality control with excellent ride and handling characteristics at real-world street speeds. HKS’ all-new Hiper Linear Piston Fluid Channel System damping system creates a positive relationship between piston speed and damping force, making it possible to produce a suspension that provides track-level control and feedback with exceptional ride quality at the same time.
Hipermax III
KSport Coilovers
Ksport Version RR Damper System is built specifically for road racing only. Aggressive rates and valving are chosen for maximum handling and performance with acute reaction and responsiveness. Integrated with 36 levels of dampening adjustment, simultaneous compression and rebound adjustment, lightweight aluminum mounts, and pillow ball upper mounts on some applications.
Kontrol Pro Kit
Key Features
36-way adjustable dampening
Made from high quality 6061 Aluminum with T6 for increased hardness
Compression/Rebound adjustable
Adjustable spring perch for height adjustment
Adjustable body allowing maximum suspension travel
Pillow Ball Top Mount w/ adjustable camber (not available for some models)
Monotube High Pressure Design reduces oil leakage
Electroplated body for protection from corrosion and rust
One Year Limited Warranty
Click the image to learn more:
Kontrol Pro Evo X
Stance Coilovers
Stnace GR+Pro [SS-D] The Special Setting Dampers were developed to meet the special demands of the circuit. The SS-D is valved to work in conjunction with race tires to maximize traction. The GR+ Pro SS-D were used to win national titles in both drifting and time attack; setting the highest benchmark for itself – winning.
Stance GR+ Pro SS-D
Moton
AST
Cusco
Tein
Don't see something listed? PM us!! We may just be in the giving mood and hook you up! ;)
Can you give me prices on all these coilovers? And are these available and ready for immediate shipment?
fortune
One last quote please. Fortune auto Dreadnoughts. Thanks
1 - 20 of 82 Posts
Status
