1 - 20 of 22 Posts
Anyone run both and can speak to which is better for someone just doing intake panel filter and cat-back exhaust (and a tune)?
Factors: Airflow, sound, filtration quality.
Looks like the Works costs twice as much as the Cossie. Any good reason for that?
Cossie at DSG: http://www.dsgperformance.com/products.asp?id=3856&catID=91&catoID=91&thisPage=&perPage=
Works at MAP: http://www.maperformance.com/works-drop-in-air-filter-evo-x-110.111.html
edit: sounds like the Works one is oiled. I'll probably go with the Cossie.
What kind of gains did you see?
16whp no tune on the Stock Map from an 2008 rom so it was the most inexpensive Mod I have done. The filter was switched on the dyno and the dealer approved that it would not void the warranty so it was awesome!!! The Metal Bracket really seals the Air Box Well!!!
Later I added UICP and Catback Exhaust and got on the same Mustang Dyno with 294WHP and 306WTQ Devintuned so it was all done on a Mustang Dyno.
Another thing I saw in the Sig from the OP was he lives in Phoenix. I ran Paper filters on both my Porsches and it was hell from the sand. Once the cars were Modified I ran the K&N Panel on one and then switched on both of them to Cones and was able to clean them which is better than buying new ones every three months.
The Works is much easier to clean than the K&N and the oil does NOT clump in spots like the K&N does.
I ran the HKS Green on the EVO VIII and hated it.
Hope this helps.
:shades:
With a stock map and factory turbo inlet it is safe. You can even add a UICP,
Intercooler, and Catback Exhaust and you will be fine.
Just don't add a Test Pipe without tuning with all those mods.
Looking for confirmation on this.
Sent from my Autoguide iPhone
+1. I have done this before myself.
Also wouldn't run an after market turbo inlet + drop-in without a tune.
fwiw i'd go for a dry filter ala cosworth.
+1 add a uicp, and you got your first mods, I guaratee you will get the modding bug, later you will do the exhaust, 3 port, intercooler, wheels, suspension, and trackdays, after that fuel system, turbo upgrade, cams, after that bottom end, and so on.
1 - 20 of 22 Posts
