1 - 3 of 3 Posts
Hi, any help pulling out the CV axle? Two of the front... I've trying with the power built 21pc. Master axle puller but no luck yet... I've done this before in cutlass Supreme, Buick regal, Toyotas etc... There's other way to make it happen on the Evo? Thanks in advance...
2008 GSR
I had to use a slide hammer - ordered from Amazon. I also had to order a larger fork, I think it was 2.5". I can double check later for exactly what I used.
I took the fork off the hammer and propped it up behind the axle cup and threaded the hammer into it that way. A couple solid whacks and it popped right out. The stub shaft may or may not come out with it.
2008 GSR
Fork
Hammer
1 - 3 of 3 Posts
