1 - 7 of 7 Posts
Do you guys bother to program in separate maps for 1A and 1B? One set is used for when the "Climate control/A/C fan is on," i.e. additional load on the engine so the BTEL on stock is slightly lower. Just wondering if I should make my own life easier and just copy the BTELs maps across instead of having 2 separate ones.
Thanks!
verkion
So that's what the decision switch is? Aircon... thanks.
I just use the same map for both.
Note that in TephraXModv1, the 1B maps become disused.
Rich
I'm not convinced, but it would be easy enough to log :)
and yes, Rich is correct, I bugger off the 1B (or is it 1A) lookup in my V1...
I thought i read somewhere that 1B is for 6th gear in the SSTs?
hrmm maybe i dreamed it!?
yep, i need to log it.
You know, for SST vehicles, it would be a 16-byte patch to re-deploy the "1B" tables. We could have:
1A Boost Target / BWGDC ... SST mode "NORMAL"
1B Boost Target / BWGDC ... SST mode "SPORT"
That'd be kind of cool..! :shades:
Preserve the low/high gear stuff as-is. Just use the 1B for "SPORT" mode.
Flick the switch and get MOOOAR power! :rock:
Edit: SPORT & S-SPORT... for all you flash Evo types, lol.
Rich
1 - 7 of 7 Posts
