1 - 20 of 727 Posts
Disclaimer: Any type of modification of your car's electrical system is dangerous and may result in personal injury and/or damage to your vehicle. When purchasing this product, you assume full responsibility and potential risks in running this DRL Bypass w/ Relay Harness.
*Vehicle Compatibility:
2008-2020 Lancer including all models: DE, ES, GTS, RA, Evo X (ONLY non-SSS halogen headlights)
2007-2010 Outlander
2006-2007 Galant
*This DRL Bypass w/ Relay Harness is also 100% compatible with Stock OEM Lights. This means Aftermarket HID's are NOT required to utilize this DRL Bypass.
The DRL Bypass will simply eliminate the DRL's. Therefore, no flickering is present when running HID's. The DRL Bypass w/ Relay Harness is completely 100% Plug & Play and requires no splicing of the OEM wiring or messing with the fuse box; Thus saving you from any warranty issues and/or headaches. With the DRL Bypass properly installed, all lights will assume standard normal function:
Position 0 - All lights OFF, DRL's OFF
Position 1 - Parking Lights ON, DRL's OFF
Position 2 - Parking Lights ON, Low Beams ON
Here's a video demonstrating the function of the DRL Bypasses that I provide:
2008 2009 Lancer DRL Bypass
*Price & Shipping:
All transactions are done via Ebay - 2008 - 2018 Mitsubishi Lancer HID DRL Bypass / Eliminator Relay Harness !! | eBay
*Return/Exchange:
Void
after 30 days from date of delivery.
Void if the DRL bypass is tampered in anyway. I will know, I made it.
Valid only for defected/faulty products.
If it’s been over 30 days, I can offer a repair service; Contact me for further info.
Installation Instructions:
I personally have been running this setup DRL Bypass w/ Relay Harness since March 12, 2009, with no issues/problems. I've also sold over 300 sets across other Mitsubishi/Lancer forum boards.
Feel free to contact me if you have any questions. Thank you for your interest! :D
Very nice. I may be contacting you about this soon
Can u make one to not have option to able to disable lights while the car running?
In Canada we are not allowed to not having day lights on.
Discussion Starter #6
Not really sure what exactly you're asking for. I understand that in Canada, daytime running lights are required.
Let say it's going to only fix the flickering and since the car starts the HID comes on.
Let say I buy the bypass you have now then I forget to turn the Lights on, As soon as the first police (PoPoss) see me with lights off, I have to say bye bye to my evo!
Isn't this just a wiring harness ? Looks exactly like a 20.00 harness that I bought.
Hey could you please pm me where you bought it from?
The whole point of the harness is to be able to turn your lights off. Otherwise they will flicker with HID's. You on the other hand can't do that as it is against the law. You are stuck with either having your headlights (HIDs) on all the time or converting back to stock halogen bulbs.
Discussion Starter #12
In that case, you're looking for an anti-flicker harness. This will automatically set your lights ON 24/7.
Discussion Starter #13
Does you're $20 harness eliminate the DRL's? What you bought is just a Standard 9006 Relay Harness.
I build an electronic circuit specifically designed to eliminate the DRL signal. I then construct this DRL Bypass circuit WITHIN a Standard 9006 Relay Harness. Hence, DRL Bypass w/ Relay Harness. This is why you're harness looks similar to mine, however, they do not function the same.
Hey I have projector headlights(not SSS) with hid. Now of course the drl still comes on no matter what click you have it on, does your kit only make the headlights come on at full click? I just want the parking lights to come on, on the first click.
BUMP for interest!
Please? :tumbleweed:
Very interested. I am sure many others are interested as well, most are just geared toward power mods.
I'll send you a PM in the following weeks when I can afford it. I am getting tired of having my lights on all the time. The car stands out more in the daytime with the HIDs on...
i am very interested. looking to upgrade my stock ass embarassing halogens to a Lightwerkz s2000 retrofit... wonder if this will interfere with their wiring... whatever, i am interested and will be contacting you when i am ready to do my retrofit.
Discussion Starter #18
I run this DRL Bypass and I also had my lights retrofitted with TSX projectors at LightWerkz. Cesar know's about my DRL Bypass. I've sold some to a few of his customers. It should work just fine. :godance:
You sir, are the man.
1 - 20 of 727 Posts
