1 - 4 of 4 Posts
I am looking at purchasing the Radium Engineering full evox fuel system. I am looking to make 700-800hp dynojet (efr 8474). How do I go about wiring these up? Id prefer not to hardwire both pumps and have them run at full kill all the time. is there a good dual fuel pump controller? Do I put 1 pump on stock wiring and the other pump on a Hobbs switch?
Would 2 aem 340lph pumps be enough? because that would simplify a lot.
What is the best course of action?
Thanks!
Bulletproof racing recently released their double pumper kit for the X that's a lot easier to wire up: https://www.bulletproofr.com/product-page/evo-x-completed-billet-double-pumper-kit
It's plug and play, no wire splicing. First pump is on OEM wiring and second is hardwired, with a built in hobb switch you just hook up a boost and source source.
Wow, wish this was around when I rewired mine.
OP - I run the Radium kit:
*Dual Hanger
*2xW450's
*2xEasy Performance Controllers
If I were to redo the system now, I would use the hanger @mikelbring has mentioned. I have the EP Controllers and will probably end up swapping them out for a simple hobbs switch setup.
1 - 4 of 4 Posts
