1 - 7 of 7 Posts
Ok so i need to bench my ecu...seems simple enough. How the the world do you remove the ecu from the car? I got the first (smaller) connector off but the bigger one is blocked by a black bracket/cover to prevent it from coming off. The black bracket is held on buy bolts that have little to no edges to grab onto with a socket/wrench or anything. The nut on the other side of that bolt is welded on and most of them cant be reached either way. The only option i see is taking a grinder and either A. grind the bolt heads off or B. just cut the whole damn bracket off.
1 - 7 of 7 Posts
