1 - 2 of 2 Posts
Car: Evo x 2011 usa.
Have a big problem with my ecu, previous owner hade fixed it with open source and full tephramod for flexifuel use. It did not work propely and lack of tuner I took the decision to go with ecutek instead. The problem we got is that now the box is pretty fucked and locked into some type of programmingmode, probobly because the ecu is hacked in the "wrong way". So when they put in ecutek license and wrote in their map all kind of errors accurd.
Any tips to get the ecu into original again?
Yeah and now I cant connect with ecuflash either, it just stops with timeout error
Yes it's normal that EcuFlash cannot read or write once your ECU has been flashed with EcuTek.
However, you can still revert it to factory state by bench flashing it. Search for the old thread on how to bench flash.
1 - 2 of 2 Posts
