1 - 3 of 3 Posts
Guys,
In Ecuflash just flashed my first map on my EDM SST, but after flash i turned off ignition as per instructions then turned on car and saw the engine check light so I went into evoscan and checked the DTC codes:
U0100: Engine time-out error
P1871: APS system (Signal abnormality)
Checked them out , and I read in a thread that the SST always throws codes after a reflash and need to clear them.. is this true?
i havent touched the tune of my car. But on my srt-10 ram when i changed the tunes with my sct tuner, the CEL and ABS light would stay on for a few kms. Then they would shut off. I'm assuming thats whats happening here, so i might be normal. Hopefully someone that knows more about this will chime in.
I can confirm that the DTC needs to be cleared on SST cars after you flash map :)
Also more importantly EDM SST cars should stay away from 3ports and AP tune, since its not reading ECU correctly and not adjusting WDGC tables correctly :)
1 - 3 of 3 Posts
