1 - 8 of 8 Posts
Longtime reader, first time poster - all issues I've had before, this forum had the answers I needed - but now I feel my situation is more unique. I've tried to search and follow all the advise in as many posts as seemed even minimally relevant.
About 6 months ago, I started experiencing an intermittent idle problem. The issue was so minor, it wasn't worth the time to try and diagnose, and didn't really affect the car's ability or reliability. I just noticed that the car would misfire once in a while when the throttle was in between adding and removing speed while on the highway. It seemed like it was more likely to happen when it was humid/raining or perhaps at higher altitude. When I would start the car, the idle would bounce a little, running between around 650 and 850.
The issue progressed enough and after switching to an android head unit which allowed me to read my ODB II information whenever, that I started looking into it deeper and tried to slowly progress through the most likely/least expensive/least effort remedies. Here's what I've been able to discover/replace over time:
(My car is basically stock, or started that way for this description of events, following regular service intervals, driven aggressive but not extreme, first owner/bought new from dealer - 2010 Evo X GSR with 78k miles on it now)
- The misfire primarily occurs in cylinder 4, occurring more frequently at idle, at about 1-2 a minute. For my last 10 drives, I average about 45 misfires per drive. All other cylinders average close to 0. While on the highway, in a flat environment and using cruise control, it never misfires.
- I removed, inspected, and cleaned my throttle. Then reset the ECU. Originally it idled high but it learned over time.
- I checked for vacuum leaks, including the common fuel pressure regulator line which I zip tied secured.
- I ran intake cleaner through, then fuel cleaner, ultimately no effect.
- I cleaned, then replaced, my MAF sensor - no change
- I replaced my up and downstream O2 sensors, somewhat as preventative maintenance, which slightly helped in other areas, but didn't affect the problem.
- I changed out my stock intake for a K&M cone with the cold air shield. It sounds awesome, but didn't affect the problem.
- I inspected, then replaced my spark plugs, using the stock NGK ones. No effect.
- I tested each cylinder's compression which had near perfect results.
- I replaced my ignition coils with no effect.
- I resistance tested the fuel injectors, without any discoveries.
- I disconnected vacuum from the master cylinder, to rule out a leak/problem with it, which proved there was no leak there.
- I tested for a head gasket leak, which didn't result in anything.
- I thought about replacing the valve cover gasket, but decided it could wait until I have to dig deeper into the engine for a good reason.
- I ran pressurized air into my exhaust and couldn't discover any exhaust leaks
What I think I could try next, but haven't yet:
- Replacing the cam/crankshaft position sensor(s)
- Replacing the fuel injector if switching cylinder 4's with another's causing the misfires to move. I didn't want to mess with the fuel rail unless I had to.
- Replacing the boost pressure sensor
- Replacing spark plug wires
Has anyone else experienced this same or a similar issue and have any advise? Any information helps and is appreciated.
Mode $06 report generated by Torque for Android
Vehicle VIN: Not present
Vehicle Manufacturer: Unknown
Vehicle Calibration ID: Not present
Test report:
MID:$01 TID:$81
- O2 Bank 1 Sensor 1
Max: 65,535Count Min: 20Count
Test result value: 32Count
PASS
MID:$02 TID:$05
Rich to Lean sensor switch time(calculated) - O2 Bank 1 Sensor 2
Max: 5,900ms Min: 0ms
Test result value: 1,100ms
PASS
MID:$02 TID:$08
Maximum sensor Voltage for test cycle(calculated) - O2 Bank 1 Sensor 2
Max: 7.99527V Min: 0.52704V
Test result value: 1.05408V
PASS
MID:$02 TID:$82
Max: 1.00003V Min: 0.31232V
FAIL
MID:$02 TID:$88
Max: 500ms Min: 0ms
Test result value: 50ms
PASS
MID:$21 TID:$83
- Catalyst Monitor Bank 1
Max: 0.09765Ratio Min: 0Ratio
Test result value: 0Ratio
PASS
MID:$35 TID:$89
Max: 5° Min: 0°
Test result value: 0.7°
PASS
MID:$36 TID:$89
Max: 5° Min: 0°
Test result value: 0.05°
PASS
MID:$39 TID:$85
Max: 766.75946kPa Min: 1.9422kPa
Test result value: 1.9422kPa
PASS
MID:$3b TID:$85
- EVAP Monitor (0.090")
Max: 1.8837kPa Min: 0kPa
Test result value: 0kPa
PASS
MID:$3c TID:$85
- EVAP Monitor (0.040")
Max: 1.3338kPa Min: 0kPa
PASS
MID:$a2 TID:$0b
EWMA Misfire counts (average) for last 10 drive cycles - Misfire Cylinder 1 Data
Max: 65,535Count Min: 0Count
Test result value: 1Count
PASS
MID:$a2 TID:$0c
Misfire counts for last/current driving cycles(calculated) - Misfire Cylinder 1 Data
PASS
MID:$a3 TID:$0b
EWMA Misfire counts (average) for last 10 drive cycles - Misfire Cylinder 2 Data
Test result value: 4Count
PASS
MID:$a3 TID:$0c
Misfire counts for last/current driving cycles(calculated) - Misfire Cylinder 2 Data
PASS
MID:$a4 TID:$0b
EWMA Misfire counts (average) for last 10 drive cycles - Misfire Cylinder 3 Data
PASS
MID:$a4 TID:$0c
Misfire counts for last/current driving cycles(calculated) - Misfire Cylinder 3 Data
Test result value: 2Count
PASS
MID:$a5 TID:$0b
EWMA Misfire counts (average) for last 10 drive cycles - Misfire Cylinder 4 Data
Test result value: 44Count
PASS
MID:$a5 TID:$0c
Misfire counts for last/current driving cycles(calculated) - Misfire Cylinder 4 Data
PASS
End of report.
Are you able to log w/evoscan and a wideband? We could probably rule out a few possibilities, and narrow things down a little.
Your fuel pump could be dying, causing things to lean out intermittently.
I'm having a bad idle issue as well just started a few days ago.
does not feel normal idles between 600-700rpm
exactly like this guy in this video https://youtu.be/yv5h6KmKKSU
Also getting random misfire mainly when shifting to 3rd slowly.
I checked my Evap purge solenoid and there is a clicking noise. Feels like
vacuum is getting stuck there, but it's only present after the car has been driven
for a few minutes.
I ordered the evap purge solenoid and check valve from the hose next to it.
You should check yours as well
I will let you know if that solved my issue.
Discussion Starter #4
I don't (yet) have an evoscan - looked into it today and not sure if I should plop $250 bucks on it - what more would it tell me then other free apps?
I was under the impression evoscan was free. Did I miss something?
NVM, forgot if you dont have the cable then you still have to drop 150 ish bucks on one
Here is an example of what I log via tactrix and evoscan:
https://datazap.me/u/metalaf/pwm-controller?log=0&data=5-6-7-8-9-10-12-13-14-15-16-17-18-19-20-21-22-23-24-25-26-27-28-29-30-32-33-34-35-36-37-38-39-40-41-42
Tactrix also gives you the ability to eTune via ECUFlash with remote tuners... which is something you should probably look into considering your "crankshaft bent while tuning".
Evoscan is either free or like $20.
good luck with finding a solution, I'm having a similar problem but it's a misfire on cylinder 4 and an dead 02 sensor for me.
If you're getting good spark you might try replacing the fuel relay, and maybe even the fuel pump. Have you already had your injectors flow tested? And have you done any other modifications to your car besides the intake? Also you might give your mass airflow sensor a clean or even a replacement.
1 - 8 of 8 Posts
