1 - 4 of 4 Posts
Was looking for recommendations for engine oil coolers, had a engine failure was looking for good options to replace my engine oil cooler
mishimoto has a neat oil cooler setup. except it is known to have fitment issues and you'll have to cut into your front bumper/fog light area to make it fit.
razorlab, do you have the MAP oil cooler and are you pushing 600+hp? If so, you have had good results? I'm in the process of upgrading my 2011 Evo X MR and oil (engine and transmission) is my current consideration. The MAP solution is intriguing, but the cooler is rated by Setrab at 325 - 425 HP.
1 - 4 of 4 Posts
