1 - 20 of 36 Posts
I'm curious if anyone has had this it is having this problem also? Turns out my 02 dump is hitting its own pipping while engaging in 1st gear causing a rattle? If so, what did you guys do to prevent this? I was thinking of wrapping the dump exhaust with a type of foam tape?
Discussion Starter · #8 ·
im going to have to go under my car and have a better look to see if this is the case. i hope it is not, cause i know its such a bitch to take off and replace this downpipe fml...
How long have all you guys had your 02 dumps in your car without any problems?
· [E-Tuner]
My MAP dump downpipe was hitting my sway bar. I had to take a propane torch to it and bent it up a 1/4", which was NOT easy at all. It was soo annoying that I almost got rid of it and went recirc.
It still rattles sometimes. I'm still thinking about going recirc, lol
**Update**
the waste gate dump has since fallen off this down pipe completely. I will have to leave it at the shop and have it welded back on. Only this time he will add some extra welds on it.
I was lucky I was idle as this piece literally fell off the car.
Discussion Starter · #13 ·
I'm going to try and weld it back on once, but if it happens again. I'm going recirc.
I've put 30K miles on my kit with no issues. I will have to check it out when I swap my turbo.
maybe you got a lucky o2 dump. :bowlol: :angrydomo: :neener::bowlol:
Discussion Starter · #17 ·
The brackets can crack off at times.
I have nothing but great respect for a company like ETS! i called them and they are willing to replace it again if it EVER breaks off again.
So i had my friend weld it back and put it back on for me! we'll see how it holds on and goes. Seems to be much better. feels good to BOOST again! :rock::dancebanana:
Discussion Starter · #20 ·
Mine just fell off. I'm sending it to ets tomorrow and they are going to make it recirc. It sucks cuz I love the dump.
were you driving when it fell off?
ETS also told me they are no longer selling the 02 dump eliminator anymore. so whoever has them still, have limited edition versions.
1 - 20 of 36 Posts
