You're tuned at 17psi? Why?
You're tuned at 17psi? Why?..PS: just got it tuned and serviced. Tuned 308KW atw on 17 psi, so hopefully its not the engine =[
Its ideling the same sorry it not up and down. just sounds like a suby and has no power while drivingThe coil that has no effect on idle that cylinder is not working for one reason or another you need to find out why check your plug, coil, and possibly comp. test
17psi is less boost than the factory tune which is like 20-21psiMid tune. I dunno, is that bad?
