1 - 2 of 2 Posts
I have a ‘13 GSR and just recently started clicking when decelerating ONLY at slow speeds. Noise seems to be coming from the rear end. I looked at different forums but not really pinpointed the issue. Clicking is pretty loud almost like loose constant rattling and does it when car is driven for a few miles. Any help is greatly appreciated.
Check for any suspension components being loose ,
check your bushings on your control arms
If all is okay then it’s possible that your wheel bearing would need replacement
Check axles to see if you have leaky boots .
ive heard if you touched your clutch / awd system recently you might have to bleed the ayc in the front and rear .
1 - 2 of 2 Posts
