just last night getting off the freeway my clutch pedal went all the way to the floor. had to go off to the side safely brought back the pedal tried re engaging first gear. clutch is very stiff stops halfway. i have the ams cmc uprgrade. managed to get a tow within the hour (honestly shocked by this but very thankful I didnt have to wait more) when the car was dropped off looked at the top of clutch pedal some leakage happened but not alot it just seemed to seep through. brake fluid was little below max. im told it might be my clutch is lost or just the throw out bearing. would like to get some veteran evo owners opinions dont want to go back and forth. thank you alot.
also turned off the car and turning back on i had to really press on the clutch pedal. tried leaving in first to turn on car would jolt and shut off. any advice helps
