1 - 5 of 5 Posts
· [Local Team Member], aka JDAVID-EVO X
I hope this helps us all and I also hope is not a repost :)
EVO X Diagnostic Trouble Codes and Malfunction Indicator Lamp (SERVICE ENGINE SOON or Check Engine Lamp) Function
DTC*1
DIAGNOSTIC ITEM
MIL*2 ITEM
Engine control module (ECM)
P0011
Intake variable valve timing system target error
P0012
Camshaft position- timing over-retarded
P0014
Exhaust variable valve timing system target error
P0016
Crankshaft/camshaft (intake) position sensor phase problem
P0017
Crankshaft/camshaft (exhaust) position sensor phase problem
P0031
Heated oxygen sensor (front) heater circuit low
P0032
Heated oxygen sensor (front) heater circuit high
P0037
Heated oxygen sensor (rear) heater circuit low
P0038
Heated oxygen sensor (rear) heater circuit high
P0069
Abnormal correlation between manifold absolute pressure sensor and barometric pressure sensor
P0096
Intake air temperature circuit range/performance problem (sensor 2)
P0097
Intake air temperature circuit low input (sensor 2)
P0098
Intake air temperature circuit high input (sensor 2)
P0101
Mass airflow circuit range/performance problem
P0102
Mass airflow circuit low input
P0103
Mass airflow circuit high input
P0106
Manifold absolute pressure circuit range/performance problem
P0107
Manifold absolute pressure circuit low input
P0108
Manifold absolute pressure circuit high input
P0111
Intake air temperature circuit range/performance problem (sensor 1)
P0112
Intake air temperature circuit low input (sensor 1)
P0113
Intake air temperature circuit high input (sensor 1)
P0116
Engine coolant temperature circuit range/performance problem
P0117
Engine coolant temperature circuit low input
P0118
Engine coolant temperature circuit high input
P0122
Throttle position sensor (main) circuit low input
P0123
Throttle position sensor (main) circuit high input
P0125
Insufficient coolant temperature for closed loop fuel control
P0128
Coolant thermostat (coolant temperature below thermostat regulating temperature)
P0131
Heated oxygen sensor (front) circuit low voltage
P0132
Heated oxygen sensor (front) circuit high voltage
P0133
Heated oxygen sensor (front) circuit slow response
P0134
Heated oxygen sensor (front) circuit no activity detected
P0137
Heated oxygen sensor (rear) circuit low voltage
P0138
Heated oxygen sensor (rear) circuit high voltage
P0139
Heated oxygen sensor (rear) circuit slow response
P0140
Heated oxygen sensor (rear) circuit no activity detected
P0171
System too lean
P0172
System too rich
P0181
Fuel tank temperature sensor circuit range/performance
P0182
Fuel tank temperature sensor circuit low input
P0183
Fuel tank temperature sensor circuit high input
P0201
Injector circuit-cylinder 1
P0202
Injector circuit-cylinder 2
P0203
Injector circuit-cylinder 3
P0204
Injector circuit-cylinder 4
P0222
Throttle position sensor (sub) circuit low input
P0223
Throttle position sensor (sub) circuit high input
P0234
Turbocharger wastegate system malfunction
P0243
Turbocharger wastegate solenoid 1 circuit
P0247
Turbocharger wastegate solenoid 2 circuit
P0300
Random/multiple cylinder misfire detected
P0301
Cylinder 1 misfire detected
P0302
Cylinder 2 misfire detected
P0303
Cylinder 3 misfire detected
P0304
Cylinder 4 misfire detected
P0327
Knock sensor circuit low
P0328
Knock sensor circuit high
P0335
Crankshaft position sensor circuit
P0340
Intake camshaft position sensor circuit
P0365
Exhaust camshaft position sensor circuit
P0420
Warm up catalyst efficiency below threshold
P0441
Evaporative emission control system incorrect purge flow
P0442
Evaporative emission control system leak detected (small leak)
P0443
Evaporative emission purge solenoid circuit
P0446
Evaporative emission ventilation solenoid circuit
P0450
Fuel tank differential pressure sensor malfunction
P0451
Fuel tank differential pressure circuit range/performance problem
P0452
Fuel tank differential pressure circuit low input
P0453
Fuel tank differential pressure circuit high input
P0455
Evaporative emission control system leak detected (gross leak)
P0456
Evaporative emission control system leak detected (very small leak)
P0461
Fuel level sensor circuit range/performance
P0462
Fuel level sensor circuit low input
P0463
Fuel level sensor circuit high input
P0500
Vehicle speed signal malfunction
P0506
Idle control system RPM lower than expected
P0507
Idle control system RPM higher than expected
P0513
Immobilizer malfunction
P0551
Power steering pressure switch circuit range/performance
P0554
Power steering pressure switch circuit intermittent
P0603
EEPROM malfunction
P0606
Engine control module main processor malfunction
P0622
Generator FR terminal circuit malfunction
P0630
Vehicle Identification Number (VIN) malfunction
P0638
Throttle actuator control motor circuit range/performance
P0642
Throttle position sensor power supply
P0657
Throttle actuator control motor relay circuit malfunction
P0830
Clutch pedal position switch circuit range/performance
P1021
Intake engine oil control valve circuit
P1025
Exhaust engine oil control valve circuit
P1231
Active stability control plausibility
P1232
Fail safe system
P1233
Throttle position sensor (main) plausibility
P1234
Throttle position sensor (sub) plausibility
P1235
Mass airflow sensor plausibility
P1236
A/D converter
P1237
Accelerator pedal position sensor plausibility
P1238
Mass airflow sensor plausibility (torque monitor)
P1239
Engine RPM plausibility
P1240
Ignition angle
P1241
Torque monitor
P1242
Fail safe control monitor
P1243
Inquiry/response error
P1244
RAM test for all area
P1245
Cycle RAM test (engine)
P1247
TC-SST plausibility <TC-SST>
P1320
Ignition timing retard insufficient
P1506
Idle control system RPM lower than expected at low temperature
P1507
Idle control system RPM higher than expected at low temperature
P1590
TCM to ECM communication error in torque reduction request <TC-SST>
P1603
Battery backup circuit malfunction
P1676
Variant coding
P2066
Fuel level sensor (sub) circuit range/performance
P2100
Throttle actuator control motor circuit (open)
P2101
Throttle actuator control motor magneto malfunction
P2122
Accelerator pedal position sensor (main) circuit low input
P2123
Accelerator pedal position sensor (main) circuit high input
P2127
Accelerator pedal position sensor (sub) circuit low input
P2128
Accelerator pedal position sensor (sub) circuit high input
P2135
Throttle position sensor (main and sub) range/performance problem
P2138
Accelerator pedal position sensor (main and sub) range/performance problem
P2195
Heated oxygen sensor (front) inactive
P2228
Barometric pressure circuit low input
P2229
Barometric pressure circuit high input
P2252
Heated oxygen sensor offset circuit low voltage
P2253
Heated oxygen sensor offset circuit high voltage
P2263
Intake charge system malfunction
U0001
Bus off
U0101
TC-SST-ECU time-out <TC-SST>
U0121
ASC-ECU time-out
U0141
ETACS-ECU time-out
U0167
Immobilizer communication error
U1180
Combination meter time-out
1 - 5 of 5 Posts
