1 - 12 of 12 Posts
Depo Racing Evo X HFC . In stock cars, the stock catalytic converter is the primary choking point to make power with a turbo. In order for the turbo to spool fast and compress the air for the engine, the exhaust needs to escape freely. If the exhaust stops flowing the turbo stops moving efficiently.
- 3″ Stainless Steel Hi-flow Cat, why go test pipe, this will give you all the flow but not the gas smell…great for the street and weekend track days, why go test pipe.
- 100 cell metal substrate Catalytic converter.
- good for 600+ whp
- Extended bung prevents Cels, Even pass inspection in some states
- Bolts up to stock or aftermarket exhaust -Perfect fit on Evo X and Ralliart
- See more at: http://www.deporacing.us/shop/mitsubishi/evo-x-hfc-copy-2/#sthash.PLtKKgf1.dpuf
1 - 12 of 12 Posts
