Bad belt but just as an.fyi we have timing chains.
Sent from my SGH-T959 using AutoGuide.Com Free App
What's your milage? Have you changed the drive belt yet? If yes, did you replace the plastic idlers as well?
http://www.motoiq.com/magazine_articles/id/1859/evo-x-tech-tips--february-2010.aspx
where are you buying the parts from? i might just go ahead and do mine too since i dont know when the last time it was changedThanks guys
It's the original belt with 55k miles on it so it's probably done.
When we did the cams I remember looking at the pulleys and they were worn
I don't think i got any antifreeze on the belt. It looked dry and I haven't seen any overflow.
Looks like I have to buy a belt and 2 pulleys!
From the grave again. Same sound. I have replaced the belt. Have metal idlers to swap in but haven't done that yet. Tension is good.bump from the grave, any solution. I just encounted this but i have relatively new belt and metal pulleys
Yep, had that on my other car - Kia with 4b11-like motor as well. I got coolant on the belt and until I replaced the belt, I couldn't get rid of the sound.If you get any antifreeze on the belt, it will make it squeak
