Well it’s just and off the shelf from cobb, just the stage 1 93It's probably the tune. Most custom tunes spike to 27-28psi and taper back down to 25psi on the stock turbo. You shouldn't have boost creep on your setup and a proper tune should be able to control it. If you have the stock boost control solenoid you should get a 3-port when you get a custom tune done too.
How did you check to see it was sticking?I had the same thing happen to me. I found out my wastegate was sticking sometimes and I was hitting upwards of 33psi
No I’m trying to figure out how to fix it myselfHave you got it checked?
I'm running the ots stage 3 Cobb map and it normally only hits 26.Well it’s just and off the shelf from cobb, just the stage 1 93
It is through the AP I am getting a boost gauge though so hopefully that’s the problemDo you have a boost gauge? Or just going by what the AP says? I haven't had an AP in forever, but I believe the "boost" it shows is not always your actual boost. It can be off several psi
