You guys f****n rock!!! Thank you!:rock:
Why thank you. I'll pass the sentiment along to the other guys! :godance:You guys f****n rock!!! Thank you!:rock:
I think draining the washer fluid is a bit silly for a street car.take out the spare, foam padding, and drain the washer fluid and you just took 60lbs outta the car.
Depends on what I'm doing. If im going to the track or drag strip I would shave the weight. Otherwise, for everyday, it would be silly.I think draining the washer fluid is a bit silly for a street car.
