1 - 3 of 3 Posts
Mitsubishi Lancer Evolution X, US model, year 2008, 5MT,
Hi,
I use a 2.0 Open port Taktrix cable Rev. H, Evoscan 2.9.
I have already a failure in the 4WD system.
unfortunatly i cannot read DTC's from the AYC
Have i adapt the open port cable for connecting.
i attach two screenshots from the Evoscan - i tried every protokol but no connect.
The Engine ECU i can connect without problems
Perhaps someone can help
Font Watercraft Parallel Rectangle Pattern
Handwriting Wood World Font Pattern
Discussion Starter · #2 ·
sorry, it seems nobody knows how to read the DTC´s from the AYC ECU
but i tried to bleed the AYC Pump with a bleeding unit from a company from the UK, and no noise in the pump at switch on! I changed the pump 300km ago with a brand new pump from Mitsubishi! Than i knocked on the motor of the pump and it was starting, i testet the actuators, all working, no air in the lines.
So the problem was the motor (again) - had the same 500km ago also with a brand new pump from Mitsubishi (warrenty exchange).
Now i drive about 50km and testet the S-AYC, all worked fine.
Hope the pumpe will not die!
Wolfgang
Wolfgang
Hi,
pump died again, now i have a replacement electric motor installed, it seems that it worked. But if the AYC have to work often (in snow or gravel) there comes a failure message in the dash that the 4WD require a service.
after starting the engine the e-motor of the AYC Pump starts und build up pressure.
After some interactions of the AYC the message aproach und the motor stops.
After starting the engine the pressure is rising to 10 Bar, then on the first working of the pump, the pressure rises 15 Bar. After more interaction of the AYC the pressure drops to 7 Bar and then the e-motor dont get power to start again.
see some pics
Can Evoscan 2.9 and the OpenPort 2.0 cable read transmission DTC's?
Automotive tire Automotive lighting Tire Hood Automotive design
Motor vehicle Automotive tire Wood Gas Auto part
Motor vehicle Automotive tire Rim Automotive design Auto part
Motor vehicle Automotive tire Gauge Automotive design Rim
Automotive tire Wheel Crankset Automotive lighting Motor vehicle
Wheel Automotive tire Motor vehicle Speedometer Vehicle
Automotive tire Tire Hood Vehicle Motor vehicle
Trip computer Speedometer Odometer Tachometer Automotive lighting
1 - 3 of 3 Posts
