Ok got everything finally loaded up.
My original Rom is 56890007 but I am using a 56890010 due to much better definitions.
When using EvoScan, my load values are completely skewed, (4000-5000 range). What do I need to do to get them to read properly?
EvoScan using "Select ECU - EvoX CAN MUTIII"
I just set the correct settings in EcuFlash for Mode23 to work. So I will test that next.
