1 - 5 of 5 Posts
I've been working on the tuning of the Ralliart and EvoX TC-SST and found some logging information. A lot of my logging involves long drives to test the warm up cycles, cool down cycles, gear temperatures and if slip is occurring. I'm in the process of building some new EvoScan Gauge templates.
I don't know if this is going to help anyone else but me but here is some fun information that I gathered.
It drives me crazy when trying to read logs and I can't tell what gear the vehicle is in except for using RPM/MPH to figure out gear ratio's when the TC-SST should be able to tell me. So we spent a few hours over some good beers to bring you these results. Hopefully it will help you.
In EvoScan the following items can be setup for logging
CAN 29-0 (Selector position/directly correlates to display)
3 = Normal
2 = Sport
1 = S-Sport
CAN 30-0 (Manual Mode Selector/slap shifter)
1 = Manual
0 = Automatic
CAN 31-0 (Gear Position Sensor)
80 = Park
82 = Reverse
78 = Neutral
129 = Automatic 1st
130 = Automatic 2nd
131 = Automatic 3rd
132 = Automatic 4th
133 = Automatic 5th
134 = Automatic 6th
49 = Manual Mode 1st
50 = Manual Mode 2nd
51 = Manual Mode 3rd
52 = Manual Mode 4th
53 = Manual Mode 5th
54 = Manual Mode 6th
I'll keep sorting information but this should help for those who are tuning SST's in the future. It helps to know what gear/mode you were in during logging.
There are many more but they still need testing to figure out the values required.
I have been trying to get Gear in Use working in Evoscan 2.9.0092
Attached is my evoscan screen.
My car is a 2008 EVO X GSR with SST running on rom 53050109 Tephram rom that inherits 53030009
How do I set up EVO scan to log mode and gear?
I get data like this:
Gear
93.18584071
93.45132743
94.42477876
95.13274336
96.37168142
97.07964602
96.63716814
93.5840708
92.47787611
95.61946903
97.52212389
94.55752212
93.05309735
95.13274336
92.38938053
94.86725664
97.52212389
94.24778761
96.90265487
93.53982301
96.46017699
92.03539823
95.30973451
91.32743363
94.24778761
97.69911504
93.05309735
97.34513274
92.12389381
96.54867257
89.69026549
93.27433628
96.85840708
89.55752212
92.21238938
95.04424779
98.2300885
88.49557522
91.68141593
94.38053097
96.63716814
99.02654867
101.5044248
89.11504425
90.79646018
92.83185841
94.55752212
96.4159292
98.2300885
100.7522124
101.9911504
86.37168142
87.38938053
89.07079646
90.7079646
91.90265487
92.78761062
94.38053097
95.13274336
The Gear in Use function that you are trying to use is based on RPM/MPH and there is a calculation to translate it.
0-41 - 6th
42-54 - 5th
55-70 - 4th
71-93 - 3rd
94-126 - 2nd
127 - 194 - 1st
It's very messy and doesn't really work the best. That's why I decided to log differently using the Can-C Bus that is included in the car.
If you want to use Gear In Use you will have to open a special window in Excel and set the different parameters for each block to make the formula do the calculation for you. It's a pain but I have it somewhere.
Or.
You can use the Can-C topology and just understand what each gear number is.
Here is what mine looks like.
Gear
93.18584071
93.45132743
94.42477876
95.13274336
96.37168142
97.07964602
96.63716814
93.5840708
92.47787611
95.61946903
97.52212389
94.55752212
93.05309735
95.13274336
92.38938053
94.86725664
97.52212389
94.24778761
96.90265487
93.53982301
96.46017699
92.03539823
95.30973451
91.32743363
94.24778761
97.69911504
93.05309735
97.34513274
92.12389381
96.54867257
89.69026549
93.27433628
96.85840708
89.55752212
92.21238938
95.04424779
98.2300885
88.49557522
91.68141593
94.38053097
96.63716814
99.02654867
101.5044248
89.11504425
90.79646018
92.83185841
94.55752212
96.4159292
98.2300885
100.7522124
101.9911504
86.37168142
87.38938053
89.07079646
90.7079646
91.90265487
92.78761062
94.38053097
95.13274336
So glad I found this, knew it could be done but didn't know how. Now I can use this on my new digital dash.
Any Ideas on how to make a formula for Evoscan so tihiat it displays actual gear instead of the code
1 - 5 of 5 Posts
