1 - 7 of 7 Posts
Hi all my exhaust Mivec is cracked and I’m trying to figure out if I’m going with a stock Mivec or if a mivec delete is the way to go? And does the mivec delete if set at zero requires a tune. Car is running GSC valve spring.
It's a not a bad idea to run an exhaust mivec delete set up but it's not necessary if you're not pushing more than 600whp. If you GSC S3 cams I would probably do it.
Discussion Starter · #7 ·
Don’t think I’ll be ordering anything from drivenfab again they never answer there emails and tried calling the number and it’s not working… Sooo bad of a service there
1 - 7 of 7 Posts
