1 - 10 of 10 Posts
If the turbo was working before, make sure your wastegate is hooked up and that the actuator is connected to the valve. Check for boost leaks as well. And yes, you need a tune with a downpipe/test pipe but that won't fix your no-boost problem.
1 - 10 of 10 Posts
