Hello does the factory exhaust have one or two cats on on the 09 Ralliarts.
Thanks and would you happen to know if high flow cats cause the CEL to come on.One.
Yes they do.Thanks and would you happen to know if high flow cats cause the CEL to come on.
Hey whats the best type of 3 inch aftermarket cat to use in order to keep the CEL off?Yes they do.
They're all going to trigger a CEL. You need to either put a spacer on the O2 sensor or your ecu needs to be overwritten.Hey whats the best type of 3 inch aftermarket cat to use in order to keep the CEL off?
Lmao!!!One thousand give or take a hundred...
Obviously, just like in all other cars. Thats the purpose of the cat. Im not aure if its possible to do it with this car but what i did with my Si, was i bought two... Its hard to explain but long story short try to ge the O2 sensor a gap between the foul exhaust and the sensor with two small tubes? If that makes any senseThanks and would you happen to know if high flow cats cause the CEL to come on.
