1 - 11 of 11 Posts
OEM GTS/RA wheels are 18x7 +46 with 215/45.
OEM X wheels will rub depending on tire size and ride height.
[X Performance Mod], [Racing Mod], [Local Team Mem
yes, that's right. Rear will need rolling for sure.
[Off Topic Moderator], [Ralliart Moderator], [Loca
yes, rims of that spec will fit on the ralliart. You will need a FULL roll from tab to tab with springs...also will advise you delete your rear tabs cause on springs you will rub the shit out of them on hard bumps (when dropped 1.5 inches in the rear) when dropped 2 inches in the rear you will need to pull your fenders out a little bit or add -2 camber....i have -1.5 camber for handling and i rub my rears still but i need to upgrade to a higher spring rate plus coilovers for a nice tight ride.
YOLO
1 - 11 of 11 Posts
