For ex: you have Buschurs double pumper that turns on above 6 psi, what's the easiest way to tell that the pump is working. If you have a fuel gauge in the cabin the pressure should shoot up correct? Or is the regulator going to keep it at the same pressure? Also I assume it is unwise to just drop in the double pumper without making any changes to the tune?
