I haven't seen anyone post one of these yet, but I recently got and installed a BB FP Red. I've been dialing in the tune today and have seen as high as 441whp/382tq but the tune was too aggressive for my taste so I pulled it back a little and the following is the result. ~50 degrees outside.
Power Mods are:
BB Fp Red
Map Shortrunner Tubular Exhaust Mani
Turbo Xs TBE w/ Ams o2 Dp
AGP FMIC
Perrin 3 Port
Speed Circuit UICP
AFE Intake
Cobb 3" FP Turbo Inlet Pipe
ID 1000's
Walbro 255 pump.
I tuned it to ~26psi on 93 octane.
Stock Cams and Stock Clutch!
I was able to achieve 23psi by 3600 and the full 26psi by 3800-3900 typically. I think that's pretty good for a Red on a tubular exhaust mani! The supplied graph has 2 pulls on slightly different tunes. I haven't dialed everything in the way I want it, but I'm pretty close so I figured I'd drop some results by.
The car feels great, the spool is plenty sufficient for my taste, and the turbo sounds sick!
UPDATE:
After a little more fine tuning, I worked with the maps and messed with upward boost correct to prevent the slight overboost spikes that often are accompanied by going WOT when already at high RPMS. The results are in the second attachment
Power Mods are:
BB Fp Red
AGP FMIC
Perrin 3 Port
Speed Circuit UICP
AFE Intake
ID 1000's
Walbro 255 pump.
UPDATE:
