1 - 5 of 5 Posts
Discussion Starter · #2 ·
dang it, forgot to log RPM's. Anyways if I'm reading this right I see I am not hitting peak boost guess I will remove boost pill. Any feedback welcomed.
just got my AP yesterday.... still having trouble linking it to vehicle... what's the boost pill do?
Discussion Starter · #4 ·
From COBB's website:
The stock boost control consists of a series of vacuum lines and two electronic
solenoids. These devices regulate the pressurized air that flows toward the
wastegate actuator. Pressurized air that is allowed to enter the wategate actuator
will open the wastegate and reduce boost pressure. The factory boost control system
works by diverting air away from the wastegate via two electronic solenoids. The
overall quantity of air that enters the boost control system and each wastegate
solenoid is determined by a series of brass air restrictor “pills”. These
restrictors have a very specific diameter to precisely limit airflow.
1 - 5 of 5 Posts
