I will be taking my Evo to the track for the first time next month. This will be first time tracking a car period. I have a few questions and concern and would appreciate feedback and any advise.
Tires:
I am still on stock suspension with stock Yokos at ~13k miles. As you might imagine, the tires a worn pretty badly, particularly on the outside. I plan on buying new tires and getting aligned immediately after this track event. To ensure my tires make it through the track session and I would like at add as much negative camber as possible all around so the tires are contacting primarily where there is the most tread. I do not have any alignment tools and do not plan on getting the car aligned before the track day.
My question is: Should I buy H&R camber bolts or a similar product to get an extra degree of camber, or will the stock 2 degrees be sufficient? For the rear wheels I plan on maxxing the eccentrics and attempting to at least make the toe equal side to side.
Brakes:
Still on stock brake pads and stock fluid. Next time I track it I will definitely do steel lines, higher temp fluid, and different pads, but I would prefer to wait to do it all together. Can the stock fluid and pads hold up to a track day?
Swaybars:
I have Hotchkis 32mm rear and front bars. I have both on the middle setting, stock endlinks up front and racingline endlinks in the rear. Will my stock fronts make it through the day?
Transmission:
I am concerned about overheating. I have removed my fog lights and recently changed my transmission fluid and filter, but still on the stock cooler. From what I understand this is a relatively fast track and there should be good airflow to the stock cooler. I also know there is heavily modded, stock transmission, ralliart sportback that regularly runs this track and has no problems.
I am also worried about positive crankcase pressure blowing my dipstick out. I have no reason to be worried about this because its never happened to me before, but it would just ruin my day.
I also wanted to know if Ill need to rotate my tires in between sessions or if most tracks switch direction every other session.
Thanks in advance,
Ryan
Tires:
Brakes:
Swaybars:
Transmission:
Thanks in advance,
Ryan
