I know there are a few X owners now, can you pleae answer this question? Thank you
I have driven both 8's and 9's but the thing is all of them were never stock. They were all modified to about 350HP. All I can say about the X is that the top end isn't that great, it seems to flaten out at around 6000 RPM. A shop has told me that this is due to the throttle backing off at high RPMs when the boost reaches a certain point. The factory boost is set to about 1.2 bars but it spikes past 1.5 bars at times. When this happens, the ECU automatically backs off on the throttle and the boost drops to about 0.8 bars.For new X owners who have either driven or ridden in a Evo VIII or IX can you please describe what the powerband feels like to redline, does the X have good top end? Thank you
True that, but maybe not many here who've owned any previous modelsI know there are a few X owners now, can you pleae answer this question? Thank you
That's a really hard question since everyone has their own opinion. If high 13's on a 1/4 mile is quick for you, then I guess you can say it is.I see, that is kind of dissapointing about the top end but it can be fixed. Other then that does the car feel pretty quick? Thanks
I was quoting what Monster Sports told me about the throttle being pulled back at high rpms when the boost spikes.SiC, are you sure that the ecu mapping isn't just programmed to pull the throttle back at redline?
That is retarted - if it is true.I was quoting what Monster Sports told me about the throttle being pulled back at high rpms when the boost spikes.
One interesting thing came up on Japanese web sites and is causing alot of questions. According to a Japanese magazine called "My Car", they are saying that the EVO X's here have a hidden governor built into the ECU for breaking in the engine. It is suppose to "limit" the engine for high output until the odometer reaches 1000km. After the engine reaches 1000km, the output of the engine exceeds 300 HP.
:wtfsign:
this is pretty dumb but i guess it could prevent premature wear on the engine.I was quoting what Monster Sports told me about the throttle being pulled back at high rpms when the boost spikes.
:wtfsign:
:wtfsign: Makes wonderfully beautiful sense that saves them a couple thousand in warranty engine repair/replacement....hmm.. I wonder why they wouldnt openly state this especially if its just going to shut off on its own in due time....I was quoting what Monster Sports told me about the throttle being pulled back at high rpms when the boost spikes.
:wtfsign:
:wtfsign:
I personally own an 2005 Evo 8 and Evo X.
Top End:
When the Evo 8 was stock it had the same boost taper which made the top end of 6000-7000 feel flat. Boost taper was 20 psi - 17 psi. The Evo X has a boost taper of 23 psi - 17 psi, but because of the more efficient turbo it doesn't feel like it falls completely flat but similar to the Evo 8.
Mid Power:
Peak Torque feels very linear all the way to redline through the midrange on the Evo X. My Evo 8 pulls much stronger and less linear to redline. The boost taper on the 8 doesn't occur until 6000 rpms. According to Vivid racing the Boost in the X starts dropping just after peak linearly till redline so it doesn't keep pulling like the 8 does. What I like is the power is linear and predictible which is probably why the SAWC likes when it determines how much torque to move around the system when it needs to adjust in real-time.
Low Power:
The Evo 8 spools slower than the Evo X. the new exhaust on the Evo X feeds the turbo much quicker and therefore feels like a larger displacement engine down low. Of course when full boost is realized it doesn't slam you back in your seat like the 8 does.
i can't really say for sure the 8 isn't stock anymore. i'm used to 300 whp car that's 3000lbs so the X is much slower. I would say the X is more predictible stock.Wow thanks for the great write up, I am sure with some tuning, a nice turbo back and an intake we can fix the taper issue and feel the turbo surge again. What you described here sounds very similar to how a 04-07 Sti feels which isnt a bad thing of course. Does the X feel as fast as the 8 to you?
