can I get the a code for 53050009
also 5639Ecan I get the a code for 53050009![]()
My guess is that the lack of A/C hardware is probably not going to cause the ECU to ignore the fan behavior since it's more based on the A/C control panel setting, not the A/C in the engine bay. If anything, you can just set these two columns equal to the A/C Off column.If you deleted the A/C, the A/C On and A/C Max numbers won't matter correct?
So all I would need to adjust is the A/C Off column?
Yeah, should be OK. Here's my latest settings.
I like the coolant temps hanging between 180-190*F, very nice.Yes. 90* F today and I happened to take a 15 minute log of my bumper to bumper crawl.
Thanks for noticing. I threw IAT, MAT in to illustrate how hot things get when the engine isn't experiencing ram air cooling. FWIW, I'm running an AEM intake.I like the coolant temps hanging between 180-190*F, very nice.
Your intake and manifold temps are really up there though! With a heat spacer gasket on the intake manifold and cold air intake you would drop a good 30-40*F on those.
I've also been looking to do something to reduce MATs. What are you using for an intake manifold spacer?Here is a 15 minute drive where I got on the highway and then lucked out at the 2 stoplights (of course) and never had to stop before arriving to a customer site. I sat in the parking lot with the engine idling for about 5 minutes and the coolant temps never got above 185*F. While my overall cooling system is definitely upgraded, this really keeps the temps very predictable and stable!![]()
I'm using the Boomba Racing Heat Spacer Gasket, it has good instructions, longer manifold bolts, and spacers for the brackets so they attach properly.I've also been looking to do something to reduce MATs. What are you using for an intake manifold spacer?
Also, do you see any difference in gas mileage with the throttle body coolant bypass? I've gone back and forth on that myself. It's there to heat the throttle plate so at part throttle, it heats up the air entering the intake manifold. Hotter air = less dense air = less fuel = better mileage.
And yes, before anyone says anything, I realize we're not driving a Prius, but there's no rule that says we can't have a fast, powerful car that also gets decent mileage.
I'll try and grab some shots next time I'm under the hood.Thanks for the data. Interested in your cooling mods. Can you snap some pictures of some of the things you've done above?
Nice. How much did they pay you for that?Well it's official
