Q1 Will this be ok if I install the turbo without tune at first?
Yes so long you stay out of boost getting to tuner.. would be advisable to get tune to send you some sort of map for safety.. i would did this personally. Also just let you tuner know that to keep the torque low on the red... you dont want a window on your block
unless you have a built block.
Q2 What sort of power can I expect just by bolting it on?
Depends on dynos but 400whp+ for sure.. just from searching around and looking at dynos..
Q3 Is it safe to do this without upgrading to a 3 port etc..?
Yes it is .. the 3port is just a better management of boost but still via ECU, it will make you hit boost sooner and hold it more
but its also dependent on WGA (holding boost more till red line)
I am not a expert or pro just passing on what ive learned from asking questions and reading so other should chime in with more experience
