Here's a Thread about the wheels: http://forums.evolutionm.net/evo-x-...ort-tc105n-18x10-5-12mm-rr-face-17-6-lbs.html
a photo of someone else with them (hope they don't mind):
They are very light wheels, and I do use the same alignment. While some may thing that alignment is overly aggressive, my fronts still wear a bit on the inside w/ autocross. Since I rotate the rears and fronts as necessary, it works out perfectly, as the rear would probably be better ~1.5° if not rotated
