1 - 13 of 13 Posts
Id1000 or Fic1100 for injectors and 255walbro w/ evo x kit.
No AFPR is needed for simply/moderate power :)
The point behind me asking is the potential of maxing out injectors on bolt ons. Upgrading injectors so there isn't as much "strain" on duty cycle (amidoinirite?). If that is done FP upgrade would be necessary. Correct?
Y'all do realise the stock pump flows close to 250lph.
I just assumed that changing the injectors necessitated a fuel pump swap.
I'm not sure that it "necessitates" a fuel pump swap, but the stock pump is pretty well matched to what you can get out of the stock injectors. You could put in some 850s and get a little more out of the stock pump, but you won't be able to really make use of, say, ID1000s with a stock pump.
Stock pump at 14v feeding a surge tank at nearly no pressure though, you'd likely never need to upgrade it.
I THINK I understood that....but it's 4AM.
So will you likely run out of IDC first, or FP capability? At what IDC should you conservatively start thinking about upgrading? I don't like running anything at it's max...
This is me trying to learn and understand...there is no immediate practical application.
If you listen to the "injector gurus" that have an interest in selling you injectors, they'll say 80% IDC is the max.
The pump and injectors will run out pretty close to each other, but the injectors will be the limiting factor before the pump. I'm right around 350whp on a totally stock fuel system and 91 octane. Evoscan tells me I'm at 100% idc. Prior experience suggests that I could get a bit more out of this stock pump if it was hardwired with 10-12 awg wire, but how much room for growth is there at 100% idc?
1 - 13 of 13 Posts
