1 - 19 of 19 Posts
I took the GTR to get tuned at HP Logic in Wellington, FL last Friday, and I thought I'd share the results:
500 awhp
494 awtq
Video:
Thanks Jack @ HP Logic!
wow. nice. not bad for the small list of mods! congrats!
Not by much.. GTR=3,800 lb, GSR=3517lb, MR=3594lb
Discussion Starter #7
The thing is, Jeremy's evo runs, low 12s high 11s...I expect my GTR to run 11 flat, if not 10.9.
Cunning Linguist
Does that have anything to do with the way the AWD shifts toward the rear in a straight line? Also, your torque is probably better.
Discussion Starter #9
I honestly don't know how the power transfer affects the acceleration.
- Power transfer, or as Nissan more specifically calls it "Torque Split", is going to be mostly (90%) to the rear wheels while under heavy acceleration in a straight line.
- My X MR ran 12.2's with a FP Red and Stock Motor.....NOT my current set up.
- Also note: The recent removal of throttle plate reduction with the MR launch control. I haven't tried going back to the 1/4 mile yet, but it should help big time getting lower ET's.
- Fun Facts:
My X MR makes 478 whp/424 wtq @ 30 psi, 93 oct. (Mustang)
My GT-R makes 510 whp/497 wtq @ 15 psi, 93 oct. (DynoJet)
Discussion Starter #13
- Fun Facts:
I agree, but is it enough to beat a GTR?
Discussion Starter #16
Your GTR has a ton of what's called "area under the curve." An Evo at the exact same WHP peak will have a lot less of this "area under the curve."
It's the nature of the beast when you put a 2.0L with a large turbo up against a 3.8L with a pair of turbos.
Hmmmm...integrals!?!?! Jk.
Ya, I figured that would have something to do with it.
1 - 19 of 19 Posts
