Need Opinion on Overbore Head Gaskets
My OEM head gasket 2.0L (86mm) Modified by AMS to 2.2L (90mm) failed. AMS claims to have had best results from OEM Mitsubishi gasket in this configuration... The modification alone looks and seems a bit risky from what I can tell however for the sake of this thread does anyone have any input on a "better than OEM" head gasket regardless of modified or not??
I am looking at Cosworth and Brian Crower thus far...
Cosworth
http://www.cosworthusa.com/store/pc/viewPrd.asp?idcategory=71&idproduct=867
Brian Crower
http://www.briancrower.com/makes/mitsubishi/4b11_misc.shtml
Here is a couple shots of my new replacement modified AMS gasket... My concern is how close to the sealing ridge the modification may sacrifice... I also ssee some small burs from the machining that also could cause some hot spots around the inside edge of the gasket...
I am not trying to cause any riffle with AMS here just looking for alternatives as a head gasket issue on this car has cost me some coin and a lot of time... Were all here to learn from eachother after all... And this issue is NOT something I want to keep revisiting...!
Opinions??
Thanks in Advance!
Cosworth
Brian Crower
Opinions??
Thanks in Advance!
